Controller assigning troubleshooting
mattko16
Hello forum,
When I attempt to set parameters for certain effects, It reverts back to its original state.
I believe I’m following the correct method:
Press and hold (for ex) a Delay parameter knob. I go to Controller Assign page
Tweak the min and max values. Then Press Knob 6 (Learn Controller). Then the desired footswitch, and HOME to exit.
However it does not save the new parameters.
Is there a global setting that’s in play here reverting it back?
thanks for input.
-Matt K
It’s within a new preset I create. There’s the default settings for effects blocks when placed in the signal chain. It’s when I go to adjust those paremters to something different, it reverts back to original default block settings. Yes I do save it after the change.
I believe you need to set the min and max values for the controller after you use the "Learn Controller" function. That's how I've always done it, anyways. I think setting the controller resets them back to 0 and 100, respectively.
I’ve been in both modes when this occurs. The min and max values appear when setting the Learn Controller. I can adjust the values to any amount and after I click the desired footswitch they return to 0 and 100. I hope this makes sense
1 minute ago, jbuhajla said:
Choose the switch you want to control first, then set your min/max.
Yeah, you just need to adjust the min and max values after selecting the controller. I don't think it's a bug, per se. I just think the min and max values go back to their default values when you pick a new controller. I don't remember if this happens on HX Edit or not.
