LewisBrunton Posted July 24, 2018 Share Posted July 24, 2018 Hi, I have just purchased a Helix and have been having great fun working with snapshots, in particular changing parameters and bypassing blocks so that I can switch between rhythm and lead tones. One thing that I would like to do is be able to switch the input from 'Guitar' to 'Aux' by means of a snapshot as this would enable me to switch from the mag pickups on my guitar to the piezo. Is this possible? Thanks Lewis Quote Link to comment Share on other sites More sharing options...
Mturner Posted July 24, 2018 Share Posted July 24, 2018 No and Yes. :) You can't change the input via a snapshot but there are at least two ways to do what you're after. 1) Make two different presets. Each preset will remember which input you selected. Depending on the presets, the output might get muted when you switch. 2) Create two different paths in the same preset, one using Guitar and one using Aux as the input. Then use snapshots to control gain blocks or merge blocks that determine which path goes to the output. Quote Link to comment Share on other sites More sharing options...
LewisBrunton Posted July 24, 2018 Author Share Posted July 24, 2018 18 minutes ago, Mturner said: 2) Create two different paths in the same preset, one using Guitar and one using Aux as the input. Then use snapshots to control gain blocks or merge blocks that determine which path goes to the output. Aha yes of course, option 2 is my best bet :) Thanks Lewis Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted July 24, 2018 Share Posted July 24, 2018 I set up my aux input on path 1A, then my guitar input starting on path 1B, connecting to path 2. Piezo connected to aux, and magnetics connected to guitar in. I use the on board expression pedal to control volume of magnetics signal, and external expression to control volume of piezo. You can use snaps to control volume rather than expression pedals. Quote Link to comment Share on other sites More sharing options...
LewisBrunton Posted July 25, 2018 Author Share Posted July 25, 2018 Got it sorted last night - mags into path 1a, piezo via aux into 1b. This is then merged into1a so that I have the option of using the effects I have setup for my mags based clean sound. Many thanks guys Lewis 1 Quote Link to comment Share on other sites More sharing options...
