vazman2
4CM and a model on separate paths... possible?
What I'm essentially trying to do is run a path into my recto with a 4 cable method using the 1/4" outputs, and run a separate path through a model using the XLR outputs. But every time I set the output of the model path to the XLR the signal for the 1/4" outputs just cuts out. I'm not running out of DSP. Has anyone tried this before? Any help would be greatly appreciated. Thanks!
You should be able to have 1 path going to 1/4" out and 1 path going to XLR out, sure. This is how some people have the Helix process their guitar and their vocals simultaneously. Can you show the patch you're using?
I'll take a pic tonight. I do have each path going to those separate outputs.
Create an account
Register a new account
Sign in
Sign In Now
