redbelo Posted August 12, 2018 Share Posted August 12, 2018 Can I Use a external ON/OFF switch to power the helix if I leave the onboard switch permanently ON? Quote Link to comment Share on other sites More sharing options...
soundog Posted August 12, 2018 Share Posted August 12, 2018 Seems that I read the answer to this before on the forums, and it is "yes." Was wondering the same for an HX Effects, and assuming the answer is also yes? Confirm? Quote Link to comment Share on other sites More sharing options...
kennyhickey Posted August 12, 2018 Share Posted August 12, 2018 I have my Helix plugged into a power strip with a few other things and just use the switch on the power strip to turn everything on/off....no issues. Quote Link to comment Share on other sites More sharing options...
Verne-Bunsen Posted August 12, 2018 Share Posted August 12, 2018 I actually contacted Line 6 directly on this a while back and was told: <ahem> "Quote: Hi, You're good to go using an external switch. Your proposed set up will not damage the Helix at all. Have fun! Thanks, Will - Line 6 Support" 1 Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted August 13, 2018 Share Posted August 13, 2018 4 hours ago, kennyhickey said: I have my Helix plugged into a power strip with a few other things and just use the switch on the power strip to turn everything on/off....no issues. Same. I've been doing this for over a year with no issues. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted August 15, 2018 Share Posted August 15, 2018 I do it all the time. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted August 15, 2018 Share Posted August 15, 2018 Why is this even a question? I've done this for going on 30 years, with more pieces of gear than I could possibly count. The juice either gets through and turns it on, or it doesn't.... makes no difference where the gatekeeper is. Quote Link to comment Share on other sites More sharing options...
duncann Posted August 15, 2018 Share Posted August 15, 2018 12 minutes ago, cruisinon2 said: ...makes no difference where the gatekeeper is. 1 2 Quote Link to comment Share on other sites More sharing options...
ParkerFlyMajik Posted August 25, 2018 Share Posted August 25, 2018 I fried my Vetta II HD that way (or it was a very unfortunate coincidence). Used a power strip switch. Seemed to be a momentary spike in power and it was toast. I have been turning things on/o in series ever since. Good to know that L6 is making things more robust these days. Quote Link to comment Share on other sites More sharing options...
