jesuscares Posted August 15, 2018 Share Posted August 15, 2018 Hi guys, I just imported my Helix hardware bundle into Helix native, but I found that none of the IRs got imported.I thought when transferring from Helix to helix (hardware) ,the complete IR list could be imported along with the bundle. Why is this not possible while transferring from hardware to native? Anything I'm doing wrong? Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted August 15, 2018 Share Posted August 15, 2018 You will have to add/import the IRs just like you did on your Helix. They will also need to be in same order as they are on your Helix for your patches to work exactly the same. Hope this helps you. Quote Link to comment Share on other sites More sharing options...
jesuscares Posted August 15, 2018 Author Share Posted August 15, 2018 4 minutes ago, VirtualGuitars said: You will have to add/import the IRs just like you did on your Helix. They will also need to be in same order as they are on your Helix for your patches to work exactly the same. Hope this helps you. Thanks for the quick reply.Yes I did add/import the IRs on Helix when I started ,but it always remained (as far as I remember) each time I did a backup.It's a bit cumbersome to match the tones with the original Its used on Helix hardware to the Native.Wish they can come up with an easy work around. Appreciate your quick reply. Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted August 15, 2018 Share Posted August 15, 2018 You can just highlight all of your Impulse Responses in Helix Edit (Control-A on Windows or Command-A on macOS}, export them all, and then import them into Helix Native. Boom. 1 Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted August 15, 2018 Share Posted August 15, 2018 4 hours ago, jesuscares said: Thanks for the quick reply.Yes I did add/import the IRs on Helix when I started ,but it always remained (as far as I remember) each time I did a backup.It's a bit cumbersome to match the tones with the original Its used on Helix hardware to the Native.Wish they can come up with an easy work around. Appreciate your quick reply. Here's a quick little utility you can run that will help you determine what IRs are being used in what slots. http://dave-merrill.com/helix/hirb/ Quote Link to comment Share on other sites More sharing options...
bsd512 Posted August 15, 2018 Share Posted August 15, 2018 A Helix Bundle doesn't include IRs. The new backup and restore method introduced last fall does, though. Here's an IdeaScale entry to implement compatibility of those backup files to be loaded into Helix Native. Not sure if it will get implemented, but for me it would be very handy. https://line6.ideascale.com/a/dtd/Ability-to-Restore-Native-from-HX-Edit-Backup Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 15, 2018 Share Posted August 15, 2018 10 hours ago, jesuscares said: Thanks for the quick reply.Yes I did add/import the IRs on Helix when I started ,but it always remained (as far as I remember) each time I did a backup......... I was similarly confused recently about the same thing. Helix and HX Edit have had, from the beginning, the Save Bundle feature which never did and still does not include IRs. It only saves the setlist and preset info. Helix Native also has this capability. in a fairly recent firmware update Helix and HX Edit added the full Backup and Restore feature which includes IRs and Global Settings in addition to setlists and presets. This more comprehensive capability has not (yet?) been implemented in Helix Native. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted August 17, 2018 Share Posted August 17, 2018 On 8/15/2018 at 9:09 AM, silverhead said: I was similarly confused recently about the same thing. Helix and HX Edit have had, from the beginning, the Save Bundle feature which never did and still does not include IRs. It only saves the setlist and preset info. Helix Native also has this capability. in a fairly recent firmware update Helix and HX Edit added the full Backup and Restore feature which includes IRs and Global Settings in addition to setlists and presets. This more comprehensive capability has not (yet?) been implemented in Helix Native. The ability to either include IRs in a bundle or a "Restore Backup" feature on Native is actually pretty high up on my feature wishlist. Until then if you make fairly frequent use of IRs and add presets on a regular basis, then syching the IRs on your Helix to Native remains a chore. Back to the bad old days of having to prepend sequential numbers in a rename of your IRs. Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted August 17, 2018 Share Posted August 17, 2018 8 minutes ago, HonestOpinion said: The ability to either include IRs in a bundle or a "Restore Backup" feature on Native is actually pretty high up on my feature wishlist. Until then if you make fairly frequent use of IRs and add presets on a regular basis, then syching the IRs on your Helix to Native remains a chore. Back to the bad old days of having to prepend sequential numbers in a rename of your IRs. I could not agree more. I would love to see some sort AutoSync feature that keeps your patches and IRs in sync between Helix and Helix Native. Quote Link to comment Share on other sites More sharing options...
supertonic_jack Posted April 3, 2022 Share Posted April 3, 2022 same! It is crazy how often I need to manually sync the IRs between native and LT. I can only export and import the files alphabetically between those two. But not in the order how I want. Quote Link to comment Share on other sites More sharing options...
BarToe Posted May 22 Share Posted May 22 Brand new Helix Rack and Native. This has been driving me crazy I was about to box up the Rack and ship it back since I started with Native two weeks ago and just got the Rack two days ago. I been importing bundle from Rack into Native but half my presets have the incorrect IR's even though the IR lists are in the same order. I just tried what VirtualGuitars said and it seems to have worked. This makes no sense since my IR list for Native is in a different order than the Rack. What kind of ridiculous programming is this? Quote Link to comment Share on other sites More sharing options...
