Dt50 212 Direct Out Recording
robyone
I want to use the direct out of my dt50 212;
My intention is the follow;
guitar, amp input, direct out, mic soundcard input...master amp level about 50%-60% (i use a SPL reducer for lowering the out volume) and add effects in cubase ( IR cab, delay or reverbs etc)
any help or suggestions?
Thank you  :)
The direct out on the DT50 has cab and mic modeling applied by default, so using an IR cab may give you some weird sounding results. If you've installed the 2.0 firmware update, you can turn that off by sending the appropriate MIDI CC message to the DT50, though.
