shawn_brawn Posted September 1, 2018 Share Posted September 1, 2018 Im having an issue with my Helix, the amps themself sound amazing but when paired to a cab it seems like half the amp disappears. The cabs seem to completely darken all of the amp sounds. Any ideas? Quote Link to comment Share on other sites More sharing options...
HeRo70 Posted September 1, 2018 Share Posted September 1, 2018 Maybe you pair an amp+cab with another cab, that sounds bad. As bad as using just an amp (not amp+cab) on its own. Pairing an amp an and a cab (single or dual) should sound nice. Please check out the block: is it amp or amp+cab? And in case, don't add another cab after amp+cab. Hope this helps. Quote Link to comment Share on other sites More sharing options...
RD1967 Posted September 2, 2018 Share Posted September 2, 2018 Please explain more on your setup or show a screenshot. It sounds like you may be using an amp that already has a cab and then choosing an additional cab. If you are choosing only the amp it will say "amp" below it on your screen. If you are choosing an amp and a cab it will say "A+C" below it....you may be adding another cab to the "A+C". If you want to use two cabs then only choose the amp and run the two cabs in parallel. Quote Link to comment Share on other sites More sharing options...
shawn_brawn Posted September 2, 2018 Author Share Posted September 2, 2018 For instance, the cartographer, if i run just the amp head, it sounds full and bright but when pared to any of the cabs it become dull and dark. Quote Link to comment Share on other sites More sharing options...
willjrock Posted September 2, 2018 Share Posted September 2, 2018 Boy i wish i had this issue. Helix sounds bright/fizzy/ no warmth at all, when paired with HX cabs. I choose IRs. Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted September 2, 2018 Share Posted September 2, 2018 The most important question to ask here is what are you using as an output device? If you're playing through a physical guitar cabinet then you don't need a modeled cab in the signal chain. Quote Link to comment Share on other sites More sharing options...
arislaf Posted September 2, 2018 Share Posted September 2, 2018 15 hours ago, shawn_brawn said: Im having an issue with my Helix, the amps themself sound amazing but when paired to a cab it seems like half the amp disappears. The cabs seem to completely darken all of the amp sounds. Any ideas? After 2 years of using helix and dealing with the same issues, i found that it requires HEAVY EQ on the stock cabs., or just some IRs. Quote Link to comment Share on other sites More sharing options...
Kingkid Posted September 2, 2018 Share Posted September 2, 2018 Yes the Helix sounds fantastic with no cab. So lets think a second. If im using a guitar cab from my Helix, i dont really need a cab or ir in the Helix. I run my Helix straight into my P.a!! Quote Link to comment Share on other sites More sharing options...
