howdy-doo Posted September 12, 2018 Share Posted September 12, 2018 Hi everyone, hope it's OK to ask as I've seen a few posts on the subject but wanted to ask about 2 specific pedals. I'm thinking of picking up the mission pedal for doing wah, and the Ernie ball VP Jr for volume. I do already have a Dunlop mini wah, is anyone able to say whether the wah sounds are up to scratch (if it's anything like the quality of the other effects it should be fine!) as if not i can just keep the mini wah but ideally I want to get the most out of the HX as possible. Thanks for all your help and sorry again if it's a frequently asked question Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 12, 2018 Share Posted September 12, 2018 That should certainly work. One thing I always think is that if you're always going to be using one expression pedal for volume, you might as well just use an actual volume pedal run your audio through it. That will free up one block in the HX, and it gives you an extra expression pedal for other things. In that case, you might want to look at the Ernie Ball MVP, which has the same footprint as the Jr., but has a nice buffered input. Quote Link to comment Share on other sites More sharing options...
howdy-doo Posted September 12, 2018 Author Share Posted September 12, 2018 Thanks for the reply. If I had the VP Jr just before the HX would the buffer be necessary as the signal would get buffered from the HX? Or would you put it somewhere else in the chain? Quote Link to comment Share on other sites More sharing options...
