Sign in to follow this
paulhaul
HX Effects with AMP channel switching
I am new to using digital equipment (analog guy) and I replaced my pedal board for an HX Effects.
Amp channel switching works fine in preset mode. However, if I want to switch to another preset, there is this short time of no sound, to load the other preset. Here comes in the snapshots, so that problem is solved. But now i cannot use amp channel switching in snapshot mode. Is there solutions/workaround to be able to switch between channels AND without that short period of nothing to load another preset or sound?
I hope somebody has an answer to this.
You can use the channel switching per snapshot. You just have to assign the EXT AMP command to an Instant Command (as well as a footswitch) and set the switch on each snapshot how you want it (and, of course re-save the preset if you have the Snapshot Edits parameter set to Discard).
Thanks! In the mean time I found this demo video about this topic. It should work and I will be a happy guitar player!
Create an account
Register a new account
Sign in
Sign In Now
