Joeleft
New Helix - Need to run License Manager ?
Hi
I have just purchased a new Helix.
I have had quite a few L6 products in the past and have run License Manager to "authorise" them.
Do I need to do this with the Helix, or is License Manager a thing of the past ?
When I ran License Manager, it could not find the Helix which is connected to my computer via USB.
Baffled.
Thanks.
Did the Helix drivers get installed? If so, are you using a USB hub? If so, don't or, if not, try a different USB port.
  • Thanks 1
The license manager isn't used for Helix. Instead, register it in your support account.
  • Thanks 1
Hi Brue58ski.
Thank you for reply.
Yes, drivers installed. No hub.
Thanks .
Have already registered the unit.
14 hours ago, Joeleft said:
Thanks .
It may help to know what computer system you are trying to hook up to.
Quite a lot of issues stem from USB connections, but as you are not using a hub it clears that point.
A little more info could help solve the problem.
30 minutes ago, datacommando said:
I don't think he's having any problems with his USB connection. The license manager simply doesn't contain Helix in it's list of devices to authorize, so it will never find it.
I thought that he had registered his Helix with Line 6, but was still having issues with his computer failing to see it?
Maybe I misunderstood the situation.
Hi Data Commander
Thanks for the reply.
I can see and use the Helix after registration, but I can't see it on the License Manager.
On all my other L6 gear, I had to "authorise" them via the license manager.
Regards.
  • Thanks 1
5 hours ago, Joeleft said:
Hi Data Commander
Regards.
Hi Joeleft,
Good to know you’re up and running. Have fun!
