daveyball Posted September 28, 2018 Share Posted September 28, 2018 Just got the Powercab112+, plugged a standard XLR form my Helix mono output in to the Digital L6 link socket on the back of the PC. No sound!! Is this correct? If I use the same cable form the Helix AES port to the PC that's fine. I have the XLR on the Helix set to line. Am I missing something or possible faulty PC? Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 28, 2018 Share Posted September 28, 2018 Huh? The PC's L6 Link input will only work with a digital signal. The signal coming from the Helix's XLR outputs is analog. The L6 Link/AES/EBU port on the back of the Helix is a digital out, so that's what you'd use to connect to the PC's AES/EBU (L6 Link) jack. Quote Link to comment Share on other sites More sharing options...
daveyball Posted September 28, 2018 Author Share Posted September 28, 2018 Thanks Phil, so can I use sorry at al from helix, into to the top input jacks? Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 28, 2018 Share Posted September 28, 2018 9 minutes ago, daveyball said: Thanks Phil, so can I use sorry at al from helix, into to the top input jacks? I'm guessing this is speech-to-text gone awry... If you're asking if you can use the XLR outs from Helix into the top input jacks on the Powercab, the answer is yes. Quote Link to comment Share on other sites More sharing options...
