JeremiahEdward Posted October 13, 2018 Share Posted October 13, 2018 Have there been any proposed working (and hopefully simple) methods of attaching Helix to a flat plywood pedalboard (Brady Case flat board)? I did a search on the forum and it brought up 153,000+ topics, with either the words "Helix", "attach", or "pedlboard" in it. Quite honestly, I'd rather be playing helix than going through them all. Thanks! Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted October 13, 2018 Share Posted October 13, 2018 14 minutes ago, JeremiahEdward said: Have there been any proposed working (and hopefully simple) methods of attaching Helix to a flat plywood pedalboard (Brady Case flat board)? I did a search on the forum and it brought up 153,000+ topics, with either the words "Helix", "attach", or "pedlboard" in it. Quite honestly, I'd rather be playing helix than going through them all. Thanks! You can safely remove them completely for mounting on a pedalboard. I am in the process of putting my Helix, (2) Mission Engineering expression pedals, and Relay G70 wireless unit on a pedalboard. The screws attached to the rubber are only there to hold the rubber feet. They don't screw to any of the internal Helix components. Just a suggestion, but you should consider the vent holes on the bottom of the Helix when you choose a location to mount it. I would make sure air can still get into the vent. Quote Link to comment Share on other sites More sharing options...
JeremiahEdward Posted October 13, 2018 Author Share Posted October 13, 2018 28 minutes ago, VirtualGuitars said: You can safely remove them completely for mounting on a pedalboard. I am in the process of putting my Helix, (2) Mission Engineering expression pedals, and Relay G70 wireless unit on a pedalboard. The screws attached to the rubber are only there to hold the rubber feet. They don't screw to any of the internal Helix components. Just a suggestion, but you should consider the vent holes on the bottom of the Helix when you choose a location to mount it. I would make sure air can still get into the vent. It's a Helix lt. I don't actually see any air vents on the bottom..... Maybe I'm missing something? Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted October 13, 2018 Share Posted October 13, 2018 I own a Helix, not a Helix LT. If there is no vent hole on the Helix LT, then you are probably good to mount it how you wish. Quote Link to comment Share on other sites More sharing options...
JeremiahEdward Posted October 13, 2018 Author Share Posted October 13, 2018 Well.. that makes things waaaaay easier. I appreciate the info. Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted October 13, 2018 Share Posted October 13, 2018 You're welcome! Please post up some photos when you finish setting up your pedalboard! Quote Link to comment Share on other sites More sharing options...
Bushman2 Posted November 20, 2018 Share Posted November 20, 2018 3M Dual Lock. I’ve used it for years. Way better than Velcro. might be tall enough to use with feet. they have lots of different hold firmness styles and they do vary height between them. something to consider. Quote Link to comment Share on other sites More sharing options...
