mikiiabuel 0 Posted October 20, 2018 Hi All, First time to post here as I really couldn't find an answer to my issue. I'm using an HX Effects with a dunlop dvp4 mini volume and expression pedal. I connected a trs cable into the aux and pedal 1 of the HX effects to control my wah position or whammy mix position. I did the learn thing, and actually the expression pedal is controlling the right parameters. However, my issue is that the heel position is correct (always 0% on whatever is being controlled), but once i get to the maximum toe position, it goes back to 0% position or what the heel position was doing. I noticed that the peak is somewhere at 70% of toe position. to clarify please see below example. Example on Wah (position vs. sound heard): max heel = bassier sound of a wah 70% of toe = treble sound of a wah max toe (100%) = back to bassier sound of a wah Example on whammy (position vs. sound heard): max heel = 0%mix of whammy sound 70% of toe = 100%mix of whammy sound max toe (100%) = 0%mix of whammy sound Can someone please advise what to do on this issue, I just need a linear relation between heel to toe vs. 0% to 100% wah position, or 0% to 100% mix on some parameters. Thanks in advance! Quote Share this post Link to post Share on other sites
teleute 0 Posted October 21, 2018 Line 6 expression pedals use TS rather then TRS connections, its a bit odd and also not mentioned in the helix manual. Luckily my dod mini expression has an option for this, when i used it in TRS mode it gave me some really odd results, as soon as I switched to TS mode all was fine. The dunlop dvp4 doesn't have a TR switch, but try a standard mono cable rather than a TRS one. That will short the R and S poles together and give you in effect the same thing. Quote Share this post Link to post Share on other sites
mikiiabuel 0 Posted October 22, 2018 Hi, I tried on a normal cable but same results. Would peak at 70% heel but back to minimun at 100% heal. I really think theres something wrong with calibrating this. I recall had same issue with an FX8 but cured it once in the pc editor as max and min could be set directly. I’ll try the hx edit if any luck to cure this. Quote Share this post Link to post Share on other sites
Pablo_Hernan 0 Posted October 23, 2018 On 10/22/2018 at 9:48 AM, mikiiabuel said: Hi, I tried on a normal cable but same results. Would peak at 70% heel but back to minimun at 100% heal. I really think theres something wrong with calibrating this. I recall had same issue with an FX8 but cured it once in the pc editor as max and min could be set directly. I’ll try the hx edit if any luck to cure this. Hi man! first of all, sorry for my english haha! I had exactly the same problem and I did this; in the hx, I put the min value in %100, and the max value in %0 (Im talking about the wah wah pedal). after that you have to check the expresion pedal knob (if you have one) that worked for me BUT, now I have another problem, and the problem is that I dont like how the swell of the pedal works. Quote Share this post Link to post Share on other sites
mikiiabuel 0 Posted October 24, 2018 Thanks Pablo, did what you said and saw that it would do as how it was set and then came back to the initial problem. Long story short I tried a different trs cable and it got cured, turns out my trs was shorting some contacts. Feel silly for not narrowing down the issue but luckily I used the software and saw how the pedal was communicating and tried other options. As for the swell you’ll need the volume block on, and set exp 1 or 2 to the output. Quote Share this post Link to post Share on other sites
WeatheredChoyy 0 Posted October 24, 2018 So you got the Dunlop volume x working with a TRS cable? i had mine working perfect with the EXP 2 jack but am finding similar problems when I try to use it with my EXP 1 jack (my amp channels only work on my EXP 2 jack as well, so I wanted to run the Dunlop Volume X in EXP 1!) just dont undertand why mine works perfect with a TS cable in EXP 2 but not EXP 1! My amp channel switching is the same - works in EXP 2 but not EXP 1!! i’ve never been so frustrated in my life! Quote Share this post Link to post Share on other sites
giulianino 0 Posted November 12, 2018 hello everybody, I had the same problem, it's a firmware 2.7 issue... back immediatly to 2.6 and both exp pedals will work good! Quote Share this post Link to post Share on other sites
macnevine 11 Posted November 13, 2018 OK if this is a bug then it explains why I am pulling my hair out with glitchyness. How do I roll back to 2.6? I have spent hours on this.... Quote Share this post Link to post Share on other sites
WeatheredChoyy 0 Posted November 13, 2018 I was having this problem before updating to 2.7 Quote Share this post Link to post Share on other sites
marciokl 0 Posted May 11, 2019 Was having the exact same problem as @mikiiabuel but with the HX Stomp. What solved the problem for me was changing the polarity inside the dvp4 mini from tip to ring and also inverting the polarity in the HX Stomp. Sounds weird but now it's all working fine with the TS cable. The only thing to note is that now, if I want to use the TRS cable for any reason, I have to change the polarity in the HX Stomp back to normal. Quote Share this post Link to post Share on other sites
mikiiabuel 0 Posted May 24, 2019 On 5/12/2019 at 5:50 AM, marciokl said: Was having the exact same problem as @mikiiabuel but with the HX Stomp. What solved the problem for me was changing the polarity inside the dvp4 mini from tip to ring and also inverting the polarity in the HX Stomp. Sounds weird but now it's all working fine with the TS cable. The only thing to note is that now, if I want to use the TRS cable for any reason, I have to change the polarity in the HX Stomp back to normal. Yeah Same thing, I just recently bought an HX stomp for home use and did similar method. Both units worked out well with this method Quote Share this post Link to post Share on other sites
mtumi 0 Posted May 27, 2019 same issue with hx stomp and mission engineering pedal ep-1. any advice other than “buy the ME L6 version of the pedal”? Quote Share this post Link to post Share on other sites
