larjim Posted October 22, 2018 Share Posted October 22, 2018 There are situations where I would like to have an delay time parameter set based on ms for one part of a song (say for a slap-back or thickener) during part of a song (say set to 75ms), but would like the time based parameter to be set up based on Note Division for another part of a song (say a 1/4-note delay during a solo). However, the parameter seems to need to be one or the other per preset. I had hoped I could (for example) have one snapshot (call it “Main”) based on the slap-back/ms setting, and another snapshot (call it “Solo”) with the delay parameter based on the Note Division, however when I push the Delay time parameter button in “Main” Snapshot to switch it to ms, it also seems to change it ms in the “Solo” snapshot. Any suggestions - I guess I could set two delay blocks and have them toggle on/off but that would be using up an extra block - not always an option.... Quote Link to comment Share on other sites More sharing options...
phil_m Posted October 22, 2018 Share Posted October 22, 2018 You can change the note value and BPM on a snapshot per snapshot basis, so you should still be able to obtain whatever delay time setting you want in a snapshot. You just have to convert from milliseconds to BPM. For shorter delay times, you may need to use a smaller note value. Quote Link to comment Share on other sites More sharing options...
larjim Posted October 22, 2018 Author Share Posted October 22, 2018 Understood - was just hoping I could set it by ms in one snapshot and note value in another snapshot, so I didn’t have to do the conversion....My “divide by 60,000” mental skills aren’t quite there <grin>.... Quote Link to comment Share on other sites More sharing options...
