Swirlygiver Posted October 29, 2018 Share Posted October 29, 2018 Has anyone replaced their battery and added a battery clip, so that they don’t have to remove the board and solder? If so, where did u get the clip, and did u also change the battery type? Quote Link to comment Share on other sites More sharing options...
Jurjens Posted November 4, 2018 Share Posted November 4, 2018 Yes i have replaced it with a batteryclip and solder on the board, type of battery = GP Lithium CR2430 and delivered by conrad.nl (German electronicsshop). The results after replacing perfect. Quote Link to comment Share on other sites More sharing options...
Swirlygiver Posted November 4, 2018 Author Share Posted November 4, 2018 Did the battery clip fit the existing solder location? And can u now change the battery without loosing memory? Quote Link to comment Share on other sites More sharing options...
Jurjens Posted November 4, 2018 Share Posted November 4, 2018 Yes on the same place, i have not testing the change with the new replacement. The best is before you change the battery to make a back-up from you amp/tonebanks (i think so, but.........) Quote Link to comment Share on other sites More sharing options...
Swirlygiver Posted November 4, 2018 Author Share Posted November 4, 2018 Did the battery clip have 3 pins? I don’t suppose u could send me a link to one? And did u take a photo of it afterwards? Quote Link to comment Share on other sites More sharing options...
Jurjens Posted November 4, 2018 Share Posted November 4, 2018 2 pins, view the picture Quote Link to comment Share on other sites More sharing options...
Jurjens Posted November 4, 2018 Share Posted November 4, 2018 Internetlink Conrad: https://www.conrad.nl/zoeken?search=cr2430&searchType=regular Quote Link to comment Share on other sites More sharing options...
Swirlygiver Posted November 4, 2018 Author Share Posted November 4, 2018 Wasn’t the original 3 pin? Quote Link to comment Share on other sites More sharing options...
Jurjens Posted November 4, 2018 Share Posted November 4, 2018 Yes en maybe you must solder a extra wire to one of the pins (i could not find a 3 pin holder) Quote Link to comment Share on other sites More sharing options...
Jurjens Posted November 4, 2018 Share Posted November 4, 2018 Photo with the replacement in my Vetta-II Combo Quote Link to comment Share on other sites More sharing options...
Swirlygiver Posted November 5, 2018 Author Share Posted November 5, 2018 Wow. Thanks for the photo. Thats a tight squeeze. Looks like the battery comes out towards the heat sink. Did u solder it yourself? Quote Link to comment Share on other sites More sharing options...
Jurjens Posted November 5, 2018 Share Posted November 5, 2018 Batteryclip laying under de cooler, this is a cooler for a another compenent. Yes i solder it. Before you do that, code the cables and take photo's because a lot of things must be reconnected. Quote Link to comment Share on other sites More sharing options...
tonystone Posted June 16, 2020 Share Posted June 16, 2020 Hi there ! Did you have to update firmware/software, after changing battery? Were you getting the " address error" before you changed the battery? I am ok with backing up my tone patches, but dont see that line 6 has the firmware/software update available on Line 6 Monkey or on there support page. Thoughts? 1 Quote Link to comment Share on other sites More sharing options...
