How To Disconnect Battery Holder Connector?
I have the replacement battery holder.  The problem is removing the old one.  There is one cable that snakes through the control cavity to the main board.  I can disconnect it from the main board and verified the new box fixes the problem by hooking it up.  So back to my question.  The part circled on the picture is where the cable attaches to the battery holder.  that cable snakes through the control cavity, but I can't snake it through without removing some other connectors and they look tricky too.  Is the part circled a connector or is it permanently affixed to the battery holder?
"Is the part circled a connector or is it permanently affixed to the battery holder?"--- That connector is soldered in to
the battery holder circuit board.
That is a JTV-59,... battery holder swaps should be done by a Line 6 authorized technician who knows the product,
as getting the battery harness wires through the cavity require removing the main board so you can get the cables
through the hole. So go with a Line 6 authorized tech on this one. If it were a JTV-69 or JTV-89F, I wouldn't be concern.
59 is different.
Going about it from the battery holder circuit board side of it is ill advised. A wrong move, connector or circuit trace damage
on the old or new circuit board or cable connector, and you'll have to start over. Static discharge into the program IC on
the battery circuit board, the program might get wiped, and you'll have to start over. Static discharge while trying to remove
the main board, the program might get wiped, and you'll have to start over,... and with a new main board.
Best to leave this one to a Line 6 authorized tech in your area, who has the right tools and experience for this.
