Any plans to have the Mission Engineering SP1-L6H Line 6 work with the HX Effects
mgrainger
Like most people, pedalboard real estate is a premium for me so having a single expression pedal that I can toggle between Volume and Wah  or any two expression functions would be great...
Are there any plans to make this feature available in the HX Effects?
  • 4 weeks later...
Having trouble with the mission sp1 expression pedal. When assigning controller, the learning function doesnt seem to work. When i change global settings the learning function works but then i cant seem to bypass wah blocks via the expression pedal etc. Anybody any tips? What are the correct settings?
not too sure on how to set up the wah.... I don't use it on the HX Effects..... BUT...... if they could get the SP1 with the switch to work like it does with the HX Stomp I'd be using the wah for sure!
Come on Line6.... make this happen... it would make the HX Effects that much better IMO
