Urgent help required. Broken exp pedal means I can't switch to external exp pedal
xxjohnboy
The exp pedal on the helix Lt has collapsed and broken. Which means I can't hit the toe switch. Which means the external pedal a roland ev5 can't be used from what I can figure. I don't have time to replace it under warranty. I have a Melbourne cup gig in a couple of hours so need help urgently to get this working. Please help. My roland doesn't have a toe switch. Thanks
Edit the patch and move whatever was assigned to the TOE over to a new button.
When you plug in an external pedal is it ALWAYS exp2... and the internal pedal becomes exp1.
You might have to re-assign a few things, but it can be done easy enough.
What he said...
