Sign in to follow this
CurveBound
Powercab edit shutting down
I was loading IRs and making patches for my Powercab Plus.  Powercab edit after a little bit of running would give an error message "No device connected"  I would have to unplug the cable and restart Powercab edit.
In the first instance, I would be inclined to assume that the issue isn't at the Powercab end, but rather with your USB cable or the computer you are using.
So, my first port of call would be to swap out cables, and if that doesn't work try a different computer.
Once you've eliminated those, you can start thinking about pointing the finger at the Powercab, at which point you should contact Line 6 support.
I wouldn't do this first because they would almost certainly suggest trying a different cable/computer, so if you can get that out of the way beforehand it would speed things up a little.
I don't remember if it's, as well, with the powercab+ but i think there were matters following the USB connection on the computer (USB2 vs USB3).....
