HX Stomp Preset Listing?
Woundtight
14 hours ago, Woundtight said:
Where can I find a list of the  factory Presets with details, blocks, settings, etc.?
No definitive detailed listing that I know of. Factory presets change slightly with each update.
If I want to edit and save, is there a preferred way to do it? or place to save an edited preset?
I have a setlist of MY PRESETS. Copy/Paste the preset I want to mod, then do it there.
  • 2 months later...
  • 7 months later...
On 2/2/2019 at 4:46 PM, GmanJeff said:
I'd like such a list, too, if anyone has one?
After updating the firmware of my HX Stomp to 2.81, only factory presets 001a to 33c are present. Is it correct? Did I lose some valuable preset in the updating process? Excuse me but I've just bought HX Stomp and it had firmware 2.65 on and I didn't check well earlier. Thanks for the help!
I think that's all the higher the factory presets go to.
6 minutes ago, dilettanti said:
So do you mean that I didn't lose any original factory p'resets or there's no way to recover 'em if they were lost? (maybe because of no compatibility?)
You didn't lose anything. If you want to make sure, you can do a factory reset by holding down FS2 & FS3 while powering up. That will clear out everything and reload the factory bundle. It would also delete any presets you've saved on your own, though. So you'd want to save those to disk before doing that.
I trust you, thank you very much!
P.S.:: btw is there a way to have  a printed list of all the initial factory presets? I bought my hx stomp three months ago and I had the 2.65 firmware installed... I just wanted to understand if the presets were different with that firmware version.... :-o
