Sergius128
HX Effects: What is the maximum power draw?
From Sweetwater regarding the stock power supply:
Tech Specs
  • Input Voltage Range:100-240V/50-60Hz
  • Output Amps:3000mA
  • Output Voltage:9V
  • Sleeve/Tip Configuration:Tip: Negative, Sleeve: Positive
  • Manufacturer Part Number:98-030-0041-05
37 minutes ago, andysimmons said:
I believe its around 1.1 - 1.2A.
Once running I believe this is correct, but I think the initial start surge required is over 2A.
