bszuwar Posted November 13, 2018 Share Posted November 13, 2018 I bought HX STOMP Premium Patches, believing that they will fit HX Effects. Unfortunately, the patches are incompatible. Is there any possibility of converting to HX Effects? Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 13, 2018 Share Posted November 13, 2018 The short answer is no... If you had both units, and you were talking about effects only patches, you could copy and paste blocks from the Stomp into the HX Effects using HX Edit. But if you're talking about patches that use amps and cab/IRs, the HX Effects doesn't have those blocks (well, it does have IR blocks, but no amps and cabs), so it wouldn't be possible to copy and paste those blocks. Open up a support ticket and explain the situation, and you should be able to get a refund. Quote Link to comment Share on other sites More sharing options...
bszuwar Posted November 13, 2018 Author Share Posted November 13, 2018 Thanks Quote Link to comment Share on other sites More sharing options...
macnevine Posted November 13, 2018 Share Posted November 13, 2018 Dang I did the same thing but have not tried them yet. The download folder is named this: GlennDeLaune-HX-STOMP-Custom-Patches-Volume1 Is this the same one that does not work? Quote Link to comment Share on other sites More sharing options...
bszuwar Posted November 13, 2018 Author Share Posted November 13, 2018 It's a different set, but with HX Stomp it will not work in HX Effetcs. I thought that the HX series devices are compatible. For me it is a waste of money. Quote Link to comment Share on other sites More sharing options...
