dandaponde Posted November 13, 2018 Share Posted November 13, 2018 Hi, I don’t know if this is a dumb question but I have my Helix set to 1/4” out to my speakers and have USB set to computer. When I open my DAW and set to record, I was wondering if I can hault the straight signal to my speakers while I monitor through the DAW. There is two signals simultaneously coming through my speakers, direct and through the DAW. I hope this makes sense. Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted November 13, 2018 Share Posted November 13, 2018 Is the monitor function of your DAW switched off? Quote Link to comment Share on other sites More sharing options...
dandaponde Posted November 14, 2018 Author Share Posted November 14, 2018 thats not the problem... the problem is when its switched on, its double from my daw and straigth playback to my speakers.. when my monitor is switched off... theres still playback direct to speakers. Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted November 14, 2018 Share Posted November 14, 2018 Ok, im not 100% on what you hope to achieve. i purposely chose speakers which had a volume control, when im recording, i turn the speakers down or off and work through headphones, that are plugged in to the ux. Quote Link to comment Share on other sites More sharing options...
dandaponde Posted November 14, 2018 Author Share Posted November 14, 2018 ok... ill try to explain better... if im recording and monitor in my daw is on, i can hear through the speakers normal playback (ie how it normally sounds with daw not even turned on) and through the daw. when i turn track monitor off, i can still hear it normally through the speakers still. is there a way to turn off playback straight to 1/4inch speaker inputs so i can have that quiet UNLESS the daw monitor is turned on? Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 14, 2018 Share Posted November 14, 2018 21 minutes ago, dandaponde said: when i turn track monitor off, i can still hear it normally through the speakers still Hear what? The Helix? Quote Link to comment Share on other sites More sharing options...
dandaponde Posted November 14, 2018 Author Share Posted November 14, 2018 2 hours ago, Triryche said: Hear what? The Helix? Yes. When I turn off DAW monitoring, I still hear normal playback like I would when I’m just playing through it normally. Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted November 15, 2018 Share Posted November 15, 2018 Ok. So you want to turn down the volume on the input from the helix? So you only hear it when you switch the monitor function on in your DAW? Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 15, 2018 Share Posted November 15, 2018 Also, if your speakers are connected to your Helix, and you want to monitor your wet tone from the Helix, typically you would leaving Monitoring off in your DAW. Quote Link to comment Share on other sites More sharing options...
dandaponde Posted November 15, 2018 Author Share Posted November 15, 2018 2 hours ago, Triryche said: Also, if your speakers are connected to your Helix, and you want to monitor your wet tone from the Helix, typically you would leaving Monitoring off in your DAW. You know I’m an idiot, I was thinking the other way around. This is definitely the answer. Sorry for my helix nOOb question and thank you! Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 15, 2018 Share Posted November 15, 2018 No worries!! Not an idiot, just new. Quote Link to comment Share on other sites More sharing options...
