Speaker playback while recording.
Hi, I don’t know if this is a dumb question but I have my Helix set to 1/4” out to my speakers and have USB set to computer. When I open my DAW and set to record, I was wondering if I can hault the straight signal to my speakers while I monitor through the DAW. There is two signals simultaneously coming through my speakers, direct and through the DAW. I hope this makes sense.
ok... ill try to explain better... if im recording and monitor in my daw is on, i can hear through the speakers normal playback (ie how it normally sounds with daw not even turned on) and through the daw. when i turn track monitor off, i can still hear it normally through the speakers still. is there a way to turn off playback straight to 1/4inch speaker inputs so i can have that quiet UNLESS the daw monitor is turned on?
2 hours ago, Triryche said:
Also, if your speakers are connected to your Helix, and you want to monitor your wet tone from the Helix, typically you would leaving Monitoring off in your DAW.
You know I’m an idiot, I was thinking the other way around. This is definitely the answer. Sorry for my helix nOOb question and thank you!
