firmware question?
DanyPage
first, excuse my language. I'm french. So, thanks Google translator!
I bought a HELIX floor two weeks ago. I downloaded and installed HX Edit 2.7
My questions: does this mean that I updated the firmware by installing HX Edit 2.7.
If not, how to update the firmware?
Thanks for your help. Very appreciate
9 hours ago, silverhead said:
No - installing HX Edit does not update the firmware. However, the HX Edit installation package that you downloaded included a program called Line 6 Updater. You need to run that, with Helix connected via USB, to update the firmware.
Thank you so much sylverhead. Very simple when it is well explained . Everything is done, my firmware is up to date.
Also, the problems I had with several downloaded presets that were not working, well, everything is fixed now
Thank you very much!!
