wmr68 Posted November 21, 2018 Share Posted November 21, 2018 Hi All I can't work out how to access the additional amp models in the HD300 (beyond the 16 available from the Amp Model Select Knob). I have gone into edit mode but cannot see how to access these additional amp models. And unfortunately the advanced guide does not tell you how to access them either. Thanks for any advice. Quote Link to comment Share on other sites More sharing options...
Triryche Posted November 21, 2018 Share Posted November 21, 2018 11 hours ago, wmr68 said: I have gone into edit mode but cannot see how to access these additional amp models. Which additiona; AMP models? Quote Link to comment Share on other sites More sharing options...
wmr68 Posted November 22, 2018 Author Share Posted November 22, 2018 From the POD® HD300 & POD® HD400 Advanced Guide, page 5.1.... "* TIP: In addition to using the Amp Model Select knob, there are also several additional Amp Models that are accessible from within the Amp Edit Mode! Please see page 5•2." From the POD® HD300 & POD® HD400 Advanced Guide, page 5.2.... "Amp Model Selection In addition to using the Amp Model Select knob, as covered on page 5•1, you can access all Amp Models from the Model menu here in the Amp Edit Mode screen. Note that you’ll see several extra Amp Models available here are not found via the Amp Model Select knob! See the table on page 5•8 for a list of all Amp Models." ..... but i can't work out how to see these extra amp models." From the POD® HD300 & POD® HD400 Advanced Guide, page 5.9.... "NOTE: The following Amp Models are accessed within the Edit Mode, Amp - Model Select menu only Blackface Double Vibrato ‘65 “Blackface” Fender® Twin Reverb®,Vibrato input channel Tweed B-Man Bright ‘59 Fender® Tweed Bassman®, Bright input channel Blackface ‘Lux Vibrato Fender® “Blackface” Deluxe Reverb®, Vibrato input channel Brit J-45 Normal ‘65 Marshall® JTM-45 MkII, Normal input channel Brit P-75 Normal Park 75, Normal input channel Line 6 Elektrik A face-melting Line 6 original Plexi Lead Normal ‘59 Marshall® “Plexi” Super Lead 100, Normal input channel Plexi Lead Bright ‘59 Marshall® “Plexi” Super Lead 100, Bright input channel Solo Clean ‘93 Soldano SLO 100, Normal channel, “Clean” mode SoloCrunch ‘93 Soldano SLO 100, Normal channel, “Crunch” mode Solo OD ‘93 Soldano SLO 100, Overdirve channel Line 6 Doom A Line 6 merging of a modded JCM800 Preamp + Hiwatt Power amp for maximum sludge Line 6 Epic A Line 6 creation offering epic sustain and distortion at nearly all playing levels Flip Top Ampeg® B-15NF Portaflex® bass guitar amp" Quote Link to comment Share on other sites More sharing options...
wmr68 Posted November 26, 2018 Author Share Posted November 26, 2018 Thanks for the replies fella's but I managed to sort it out. Firmware update from 1.10 to 2.01 and the extra models (plus other features) appeared. Took 3 attempts to update successfully though. For a few minutes there it was a brick but all good now. Didn't do anything different on the third attempt but there you go. Quote Link to comment Share on other sites More sharing options...
