axlaxeman Posted November 22, 2018 Share Posted November 22, 2018 Hey guys, Did a search, didn't find anything, posted on facebook and didn't get far, so I'm trying here: using the low and high frequency cuts, can you make the fasel wah pedal in helix behave like the GCB-95Q and SW-95? I know the last two have a +15dB boost, and I assume you can use a gain block to do the same thing? if anyone has done this and would care to share settings and also boost before/after pedal? Quote Link to comment Share on other sites More sharing options...
themetallikid Posted November 23, 2018 Share Posted November 23, 2018 Yes, I do this, not to mimic a specific wah pedal, but just to get a sound that I like. I usually use the Fasel model, low cut down to about 220hz, high cut at 1.9khz. I'll put an OD in front, which one varies with the gain of the preset I'm using. Its either a Valve Driver or the Kinky. I dont remember the Valve settings, but the kinky was usually bright/boost both on, and the drive set to around 5. This just gave the wah a more resonant, aggressive sound to me. Quote Link to comment Share on other sites More sharing options...
