david645 Posted November 23, 2018 Share Posted November 23, 2018 HI I have problem with my pod hd500x I used him before on windows and it worked without any problems. Now I tried to install on Macbook pro ios MOjave and I cannot do anything. I download licence manager and Monkey. I opened programme and he didnt find USb connection with POD. Is anybody had this problem ? Quote Link to comment Share on other sites More sharing options...
jego-123 Posted November 29, 2018 Share Posted November 29, 2018 Hi, It was not my idea but try this, it`s work for me. macOS 10.13 and 10.14 has implemented an additional security layer for kernel extension drivers, such as the Line 6 audio drivers. After the Line 6 device is connected, the customer must open the Security Control Pane and accept the Line 6 driver in order for the device to be recognized. Typically, but not always you'll see this message when your driver gets blocked, or is not available for use with your DAW: However, sometimes the driver gets blocked and the message won't appear. Your driver and hardware simply won't work. In either case, you'd need to approve the driver in System Preferences > Security & Privacy: Additional information about this change can be found at https://developer.apple.com/library/content/technotes/tn2459/_index.html#//apple_ref/doc/uid/DTS40017658 For some cases if the "Allow" button does not change anything, or the "Allow" button does NOT disappear after clicking. Please try these steps: Go into: System Preferences > Keyboard > Shortcuts > Select 'All Controls'. Then: Go back to System Preferences > Privacy & Security > Press 'Tab' until 'Allow' is selected > Press 'Spacebar'. Note: the Privacy & Security page may need to be unlocked before 'Tab' will work. 1 2 Quote Link to comment Share on other sites More sharing options...
salcedito Posted December 1, 2018 Share Posted December 1, 2018 Thanks! it worked for me! Quote Link to comment Share on other sites More sharing options...
rodrigoea Posted March 5, 2019 Share Posted March 5, 2019 didn't work for me, there's no such message in the Security Panel, any idea? 1 Quote Link to comment Share on other sites More sharing options...
mminino Posted May 27, 2019 Share Posted May 27, 2019 Genius!!! its working!!! THANKS!!!! Quote Link to comment Share on other sites More sharing options...
reschb Posted July 20, 2019 Share Posted July 20, 2019 This worked for me: 1. Do NOT plug in USB. 2. Install Line 6 Monkey, keep USB unplugged, do NOT install drivers or anything, reboot. 3. Install POD HD500X Edit, reboot. 4. Make sure Line 6 programs are closed. 5. Open Line 6 Monkey, and install drivers (see above "Allow" comment, if applicable), reboot. 6. Plug in USB. 7. Open Line 6 Monkey to ensure USB is recognized. 8. Open POD HD500X & begin receiving presets. 1 Quote Link to comment Share on other sites More sharing options...
Disore23 Posted September 8, 2019 Share Posted September 8, 2019 It worked for me in 8th of september 2019. I'm using POD HD500X with my Macbook Pro Mojave 10.14.6 Quote Link to comment Share on other sites More sharing options...
amicmbird Posted September 30, 2019 Share Posted September 30, 2019 Wow that worked for me too thanks Quote Link to comment Share on other sites More sharing options...
Kartiksagar14 Posted May 13, 2020 Share Posted May 13, 2020 On 7/20/2019 at 6:39 AM, reschb said: This worked for me: 1. Do NOT plug in USB. 2. Install Line 6 Monkey, keep USB unplugged, do NOT install drivers or anything, reboot. 3. Install POD HD500X Edit, reboot. 4. Make sure Line 6 programs are closed. 5. Open Line 6 Monkey, and install drivers (see above "Allow" comment, if applicable), reboot. 6. Plug in USB. 7. Open Line 6 Monkey to ensure USB is recognized. 8. Open POD HD500X & begin receiving presets. Thanks a lot!!! It worked for me too :) Quote Link to comment Share on other sites More sharing options...
