ajaykumar Posted November 9, 2013 Share Posted November 9, 2013 I got one of these this week and have been messing around with it but I can't seem to get the looper to work. I access the looper by pressing the looper button on the board, then I hit record, play something, then i hit play/stop, but nothing plays back. Am I missing something? Quote Link to comment Share on other sites More sharing options...
ajaykumar Posted November 10, 2013 Author Share Posted November 10, 2013 Help please? I still can't get it to work. I'm following the manual exactly but nothing records and nothing plays back. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 10, 2013 Share Posted November 10, 2013 That sounds strange - the Looper should work as documented. Where did you get your device? Can you return/replace it? Quote Link to comment Share on other sites More sharing options...
ajaykumar Posted November 10, 2013 Author Share Posted November 10, 2013 Is the unit defective? I bought it new from Amazon.com. I can return it but not replace it as I bought it from Alto Music "fulfilled by Amazon". Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 10, 2013 Share Posted November 10, 2013 I don't know that the unit is defective, but if you are following all instructions in the manual as you say you are.......... it should be working. Here are a couple of things to check: - System Setup menus, page 1: Set Looper FS to ALL VIEWS - when you engage the Looper, do you see the Looper Display, showing the footswitch functions? If not, either your device is defective or you need to reinstall the firmware. - In the Home Page (Signal Flow View) select the Looper to display its settings. Make sure that the Looper Playback volume is at full. Also, be aware that the Looper has no sense of timing or tempo - it will record anything it hears (including silence) for the interval between the moments that you press the Record and Stop/Play switches. So if you recorded some silence before starting to play, then that's what you will hear at first on the playback. Quote Link to comment Share on other sites More sharing options...
ajaykumar Posted November 10, 2013 Author Share Posted November 10, 2013 Thank you I was really stumped there but the issue was my looper playback volume was all the way down. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 10, 2013 Share Posted November 10, 2013 Great - glad your device is not defective. Quote Link to comment Share on other sites More sharing options...
