Need Help
MIKEY9966
HI i have been using pod for one year , have used the tuner many times , it will not cut out when  turned on, it used to drop the audio when tuning , and i used it for a kill switch to.. now the sound is leaking into my 2 amps and interface when tuning , i have looked for this topic and cant find anything  , and need to fix this before my next jig , thanks
  • Downvote 1
Essentially the tuner on Mute is a global device mute feature that can be activated and left on for as long as you like. The device CPU will be confused as h#ll trying to calibrate the incoming frequency for the duration, but it will recover nicely as soon as the tuner is disengaged.
