marcustrotta
Helix HX Stomp Routing Options
Is it possible to connect an acoustic guitar with 2 pickups to the HX Stomp (L and R) and then have different effects applied to each channel? I use a piezo and a magnetic pickup, but I'd like to have different effects and blend the result at the end.
Tks, Marcus
You can split the inputs in to two different channels with different effects, and then recombine them. It's all within the 6 block limit, but yes.
Thanks for the quick response. Do you know how to split both channels? I can't seem to find a way to do it. Using send R only works, but then I waste a block just to send the right channel.
Create two paths and move the split Y block all the way left. Set Balance A to L100 and balance B to R100. Route the mixer block to Path B (Send L/R).
This should allow you to process two instruments, or two discrete outputs, simultaneously.
