matthewklein Posted December 10, 2018 Share Posted December 10, 2018 On Helix Floor I run my monitor feed into a return and have the output set to 1/4 so that my XLR sent to front of house is only my guitar signal. That way I don't need a monitor pack, I just run a headphone extension cable along with my guitar cable and I'm set. Is this possible on HX Stomp? More specifically without eating up a bunch of blocks? If not, I beg you line 6 to add this functionality! Thanks! Quote Link to comment Share on other sites More sharing options...
matthewklein Posted December 11, 2018 Author Share Posted December 11, 2018 I guess I'm alone. Well, in case anyone else is interested this is totally doable, but it costs 1 block. Set the "return type" to return. Set "phones monitor" to send. Probably want to set volume control to just control the headphone output. Then you want to set a y split at the end of your guitar chain and a return block on path B. Then move the mixer to path B. use the mix on the control block to balance the in ear mix. I'm over the moon I managed to make this work! Hopes this helps someone! PS it would still be killer if you could do this without eating up a block. Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted December 11, 2018 Share Posted December 11, 2018 I gotta be honest, I'm not at all sure what you're trying to do here. I keep trying to visualize it and my brain breaks. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted December 11, 2018 Share Posted December 11, 2018 Great Idea! My HX Stomp is on order. I intend to use it a good bit of the time with IEMs or Headphones and as a USB Interface to my Dell XPS 15 running Helix Native. Yet to determine how it may also serve well as a DSP extender with my Helix Floor. Quote Link to comment Share on other sites More sharing options...
matthewklein Posted December 11, 2018 Author Share Posted December 11, 2018 2 hours ago, Kilrahi said: I gotta be honest, I'm not at all sure what you're trying to do here. I keep trying to visualize it and my brain breaks. I like to be able to bring audio into the HX, hear it through the HX's headphone output mixed with my guitar signal, but only send my guitar to the main outputs. That's how like to monitor the rest of the band and hear click tracks and whatnot. Saves me from having to have a monitor pack and worrying about batteries. I just run a headphone extension cable along with my guitar cable to the HX and I'm good. Quote Link to comment Share on other sites More sharing options...
zolko60 Posted December 11, 2018 Share Posted December 11, 2018 In others words: You would like to have option of setting Returns globally to chosen output to avoid in messing with patching within presets. If I am right, so please submit it to ideascale, I will upvote it. Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted December 11, 2018 Share Posted December 11, 2018 10 hours ago, matthewklein said: I like to be able to bring audio into the HX, hear it through the HX's headphone output mixed with my guitar signal, but only send my guitar to the main outputs. That's how like to monitor the rest of the band and hear click tracks and whatnot. Saves me from having to have a monitor pack and worrying about batteries. I just run a headphone extension cable along with my guitar cable to the HX and I'm good. I THINK I understand what you mean. You want to have the guitar signal sent out - nothing but the guitar/effects/etc., but have the rest of the band mix come in to the Stomp for you to hear through the headphone jack. However, isn't that done by simply setting the return/aux in in global settings to auxiliary in? I do the same thing almost every night when I play along to music on my phone. Music comes in through auxiliary in (in your case it would be the band), but only the guitar is sent out the mains. It doesn't take a single block to do it either. The only thing I'm not sure about - whenever I've done this I'm jamming along to headphones. I haven't had an amp connected - but I really think that as long as you have it set to auxiliary in it doesn't output it to your amp or PA (because in many cases that would sound freaking awful and I'm assuming they knew that). Try it and see. The key is that you have to make sure you change the Global Settings. I'm going off memory here, but I think it's: Global Settings >>>> Ins/Outs >>>> Return Type >>>> Aux in Let me know if I'm way off base here. Edit: Okay, I found the page in the Stomp manual that discusses it. Another thing it points out is that you need to make sure that the preset's input block is the "main L/R" though I think most are set that way by default. If you want to read up on it it's page 6 and page 41. Page 6 explicitly states one purpose of the aux in could be used for monitors so I hope this is what you're talking about. https://line6.com/data/6/0a020a4010c935bb66a4c0c44f/application/pdf/HX Stomp Manual - English .pdf Quote Link to comment Share on other sites More sharing options...
matthewklein Posted December 11, 2018 Author Share Posted December 11, 2018 I did try just using AUX in and it was coming out the main outputs. I figured out another solution that doesn't use a block. Set AUX IN, Set headphones to monitor main outputs, put all guitar chain on path B, give FOH the Send output. In that setup all I would hear is the monitor feed, but I my guitar will be in there anyway, so no problem. Actually, that might be the smarter way to do it and it leaves all 6 blocks available. The only downside is I can't use a separate path in making my guitar tone, but I never do that anyway. Thanks guys! You got my gears turning and now I have a couple of solutions to try out. 1 1 Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted December 11, 2018 Share Posted December 11, 2018 I've been wondering about this type of functionality for awhile now. I wonder how hard it would be to implement the IO like a regular old digital mixer, assign inputs to different outputs, change I/O levels, etc. It would be super cool to use the Helix (especially the rack version) as a hub for live audio. You could assign USB returns to different outputs to send backing tracks out to the PA, send click to your drummer's, mixer, send and input with a monitor mix through the headphone output, etc....that would be pretty sweet. For my band that plays with a click exclusively I was considering just plugging straight into my XR18 and using Native for guitar processing and sending a bus output with just guitar to a splitter for my stage sound and FOH, but I'm not THAT comfortable with the computer doing all my processing (yet). Quote Link to comment Share on other sites More sharing options...
perrymusica Posted December 12, 2018 Share Posted December 12, 2018 On 11/12/2018 at 14:28, matthewklein said: Intenté simplemente usar AUX y salía por las salidas principales. Me di cuenta de otra solución que no usa un bloque. Establezca AUX IN, ajuste los auriculares para monitorear las salidas principales, ponga toda la cadena de guitarra en la ruta B, otorgue a FOH la salida de envío. En esa configuración, todo lo que oiría es la alimentación del monitor, pero mi guitarra estará allí de todos modos, así que no hay problema. En realidad, esa podría ser la forma más inteligente de hacerlo y deja los 6 bloques disponibles. El único inconveniente es que no puedo usar un camino diferente para hacer el tono de mi guitarra, pero nunca lo hago de todos modos. ¡Gracias chicos! Tienes mis engranajes girando y ahora tengo un par de soluciones para probar. Hola, yo lo uso asi. La salida de auricular directa a los parlantes y me funciona. Quote Link to comment Share on other sites More sharing options...
karlkaminski Posted April 10, 2019 Share Posted April 10, 2019 +1 I did something similar to @matthewklein Send out to FOH Attached FS1 the Send L block to mute as needed, (allowing me to silently monitor AUXin and patches with a mute to FOH) Pros: you can use headphones to monitor PA and Main Input Cons: you lose a block and you can't use Main outs (@matthewklein idea of using PathB for signal saves block) Please post any ideas to send AuxIn directly to phones jack (without MainLR). Thanks! Quote Link to comment Share on other sites More sharing options...
danterry Posted February 3, 2020 Share Posted February 3, 2020 On 12/10/2018 at 11:19 AM, matthewklein said: On Helix Floor I run my monitor feed into a return and have the output set to 1/4 so that my XLR sent to front of house is only my guitar signal. That way I don't need a monitor pack, I just run a headphone extension cable along with my guitar cable and I'm set. Is this possible on HX Stomp? More specifically without eating up a bunch of blocks? If not, I beg you line 6 to add this functionality! Thanks! Brilliant, Matthew Klein. I was just thinking of something similar for the new Line 6 Pod Go. (I know it doesn't have the XLR outputs). Figured with this set up I could always monitor my guitar in stereo even if FOH uses mono feed for guitars. This should be a software thing for Line 6 to do globally. Maybe just have a setting where Aux in/Return can be routed just to headphones. Quote Link to comment Share on other sites More sharing options...
kurilluk Posted July 10, 2023 Share Posted July 10, 2023 I really need this function of sending AuxIn/Return directly to phones jack (without MainLR) for my looper and drum maschine which I would live to monitor on HX phones. I already asked Like6 about possibility to add this functionality to global settings. It should be feasible and easy to do - i hope, just add a new routing settings to existing menu :). We will see. I didn't get any other idea how to solve it. Quote Link to comment Share on other sites More sharing options...
juansohi Posted October 15, 2023 Share Posted October 15, 2023 Hi! I really need this function too. Aux signal in the FOH is a mistake. Listen the tuner only through headphones would be desirable too . Quote Link to comment Share on other sites More sharing options...
