Controller Assignment for Delay Time
Sonic-Imagery
Is there a way of assigning the Note-Sync portion of the Delay Time to a particular Snapshot? When I do it effects all the other Snapshots, which is not what I want. I do have the Snapshot Edits Preference set to Recall under Global Settings which is working well with all other Snapshot Controller Assignments with the exception of Note-Sync. Is there something I'm missing? Thanks for any information and help regarding this matter... :)
7 hours ago, phil_m said:
You can change the note value on a snapshot per snapshot basis, but you can't change from a note value to a millisecond value.
I really wish this wasn't the case... I could seriously cut down on the number of delay blocks I need if I could just bounce between "note value" and "ms value" in snapshots.
But - it is what it is, there must be a reason they can't implement it... I can work around it easy enough thanks to the number of blocks I have in the LT.
