jaxonhargrove Posted December 13, 2018 Share Posted December 13, 2018 Hey everyone, Does anyone know a way to switch the location of the Mode and Tap buttons on the HX Effects? The band that I play in requires a lot of tempo specific effects, so I have each song programmed into the unit via presets and snapshots, so I almost never use the tap tempo button. I do however, use the mode switch to jump back and forth between preset/snapshot view and pedal view. The problem is that I often accidentally bump the tap button when reaching for the mode button to switch views, which throws off the programmed tempo. Anybody know of a quick way to get around this? Even if I could lock the tempo or disable tap for each preset, that would be a huge help. Thanks! Quote Link to comment Share on other sites More sharing options...
