kcoulter
HX Stomp and MIDI - some insights
I bought my Stomp and I absolutely love it. I wanted to integrate it with my Voodoo labs PX8+ and I started to do some research and found so much back and forth on this topic and still a lot of confusion.  So I thought I’d list out some details here that I hope will clarify the Stomps capabilities:
The Documentation on midi is confusing:
Yes, yes it can be, but like most of Line 6 documentation there are hidden gems (like look at the Stomp manual and the ‘Reserved’ MIDI command section - very last entry.  It’s prettt funny).  Also, they don’t always list everything you need to know, but there are some not-so-obvious things listed I’ll explain next:
Can you program MIDI on the Stomp:
Typical Engineering answer ‘it depends’.  What is programmable I’ve found so far is that you can ADD blocks forSend/Return with Mono or (Stereo options) of Send Left&Right (Send L/R), Receive Left &Right (Receive L/R), and FX Send&Receive ( FX S/R) for MIDI devices.  Each connection has the capability to Bypass (as you would think Bypass an effect), Dry Thru (think n terms of how much of a dry signal), and Send (how you want to send your signal). There are also additional options on the return side and FX Loop.  This is all CC based control structures.  This is where CC controls can be programmed for these blocks that will be sent AND also the CC number will be received if the Stomp is Setup.
Is that it?:
Of course not!  You can also tweak individual effects within the presets or individual effects or amps with MIDI CC controls - however, you should k ow what your doing here as they existing functions are already defined for ‘standard operations’ (I.e. Footswitch 1&2, etc).  And if your really good at MIDI programming I’m sure there are ways to manipulate these functions (I, however, am not).
Well, my MIDI function has presets that require PC controls:
Yup - you can send PC messages also.  In the documentation where MIDI is described, it discusses under preset and snapshot recalls, in the Play View, you’ll see the PC and associated CC controls for that preset and snapshot.  Here’s where you’ll need a MIDI receiving device that is either programmable or has a ‘Learn’ mode (which is how I got my PX8+ to work).  The PC and CC controls are sent automatically (unless you change the Global Settings to do otherwise).  To program my PX8+, I setup my presets, put it into learn mode (see PX8+ documentation), selected the patch, then associated the PC and CC commands to my preset.  It takes some
time to do this.
So is there anything like the HX FX MIDI?
Nope.  Like most things Stomp, there are always some sacrifices made for the smaller form factor.  So MIDI doesn’t have the easier Controller programming function you have with The full blown Helix and Helix FX boards.
I hope this help help everyone understand what’s available a little more.  Ultimately, you’ll have to get creative to try to program some MIDI functions working in the framework Line 6 has given us with Stomp, but most things can be done creatively with the MIDI interface.  It’s more flexible than I thought, but does take some trial and error to work through.  I’m sure an entire manual could be created on MIDI programming with Stomp.
I hope this helps.  And remember to backup your pedal BEFORE you start testing how to get your MIDI functions to work correctly - just sayin....
  • Like 2
Thanks for the feedback.  This is something I keep debating getting into mostly because I love the Stomp and there's a desire to squeeze every last drop out of it.
At the same time though, I find that it's original design is actually pretty well thought out. So much so that I find myself asking what I would truly need the Midi for. The big obvious takeaways are that you can make the largely worthless looper suddenly pretty flexible (as I understand it, with the midi you can have it be a multi button looper instead of the dopey single button) and to switch presets faster.
Currently I attach a dual footswitch to the Stomp and set the footswitch to control snapshots. I then put core stomp buttons on the FS1 and FS2, leaving the FS3 for tuning and delay timing. Then I can do drastic changes with the dual footswitch, but subtle changes with the FS1 and FS2.  It works great!
Switching presets though is still a lollipop. Come to think of it maybe I should do the FS4 and FS5 for core stomp boxes and use FS1, FS2, and FS3 for snapshots because then I can change presets.
Of course then I lose the tap tuner/delay easy access but that's used a lot less often . . .
Hmmmm . . . back to dreaming of a midi controller.
  • Thanks 1
For OP's original need, the Stomp sends PC#s which can be used to control the loops on his switcher. If you need more buttons to Bypass Blocks or call snapshots via MIDI using a foot controller, or control parameters using a MIDI Expression Pedal, you can do that too. But the only affordable do-it-all foot controller I know of is the FCB1010, and it's roughly the size of a Helix Floor. By the time you add all the external MIDI controllers, you might as well get the full Helix. However, If you add MIDI enabled hardware pedals (Strymon for instance) into the Loop Switcher, something like the FCB1010 could be VERY useful. All you need is a LOT of real estate.............and again, most of what you need can be done with the full Helix.
Great topic!
I'm wondering if there is a way for the HX Stomp to send through usb midi the signal of the analog expression pedal connected in the input of exp?
Regards!
Luis
7 hours ago, zelasa said:
Great topic!
Regards!
Luis
Sadly, no. That is beyond the capability of midi.
This:
http://midisolutions.com/prodped.htm
Plug your expression pedal in, midi cable to HX Stomp, Global set to MIDI THRU=ON
EDIT: I'm assuming you want to do this to record the exp pedal movements in a DAW. To control the STOMP at the same time you'll need to assign the parameter to be controlled to MIDI. See the manual for specifics.
  • Thanks 1
43 minutes ago, rd2rk said:
This:
Huh . . .  interesting idea. I guess that makes sense, though if that's what he was after I clearly misunderstood.
  • Thanks 1
I think what he was hoping was that the analog to midi conversion was a function within the Stomp. So "That is beyond the capability of the STOMP'S MIDI" would have been quite correct! Or, it could be ME that totally has no idea what he's after!
Hi Guys, Thanks for the answers!
OK, i do not agree with "that is beyond the capability of midi" but agree with "That is beyond the capability of the STOMP'S midi"
Anyway I am asking Line 6 to confirm this because from what I can understand the implementation of the pedal, and the way this kind of system understands an external expression pedal to control internal digital effects, turning the expression pedal potentiometer analog range (which has already been converted to digital inside the pedal) into MIDI messages, depending on the implementation , it would probably not be a hardware question, but a firmware one.
Well, I may be completely mistaken and talking a lot of nonsense too... :-)
Regards,
Can the Stomp pass through all MIDI data received via its MIDI out port? For example, if my setup was “MIDI controller keyboard > Stomp > Synth module” would the Stomp allow the MIDI note data sent from the keyboard to be passed onto the Synth?
I’m sincerely hoping the answer is yes!
I believe it will send MIDI Note data. I think the only thing it won't send are MIDI Sysex messages.
Thanks for that. So you mean, even if the sysex data is sent from a controller earlier in the chain, the Stomp won’t pass thru that signal?
Correct.
Why does have MIDI ins and outs then? The world may never know...
I've read Line 6 left out the Controller section (sending MIDI CCs via the footswitches to external devices) because they thought it would make the manual too long. Not because it has a small form factor. It could be added, and would make the devices more compatible. I think its a major shortcoming for the Stomp, and the only reason I returned it.
Yeah, why did they add the MIDI out if you can't really use it for much?!
Well, they could conceivably add it later. That might be cool, though the limited number of buttons limits it somewhat.
For now though, the midi in is obvious.  it allows you to control the Stomp with a Midi controller.  The midi out is still useful too. It allows you to connect a midi controller to the Stomp, and then another midi device to the Stomp out, and the messages get passed through it.
I currently do this with a midi controller, the Stomp, and the Firehawk 1500.
When you select a preset, the Stomp can (if enabled) send the corresponding PC (MIDI Program Change) #. This can be used to call a preset on a device downstream (any MIDI enabled device like a Strymon).
Sysex messages are much longer than simple MIDI messages. They're typically used in advanced MIDI configurations, complex synth and lighting, etc. Not what the Stomp is made for. Why doesn't a Toyota Prius have a 500 HP engine?
55 minutes ago, soundog said:
I wish mine did sometimes.
My KIA dreams about being a Ferrari!
So it can be used as part of a larger MIDI rig...
.... for being controlled yes, but not for controlling (other than pc#).    :-(
Hi Phil, been a while! Yes, I see that as part of the bigger picture now. I just assumed it would do so as my M9 does it. Been out of the loop for a while and was originally shooting for the HX Effects which does all of what I was looking for. I was hooked by the smaller footprint of the Stomp as I am trying to keep it light for stage travel, oh well. For the record, I really love this little box!
Glad its working out for you. I currently use the HX Effects, but ordered a Stomp to try out because of the smaller footprint. After using it for a week I returned it — it didn't have the robust MIDI capabilities of the HX Effects. If Line 6 adds the missing MIDI features I'll pick one up again, because I really liked the rest of the package.
Exactly! Looks like I'm going with the HX Effects as well
6 hours ago, tamirh67 said:
What midi abilities were you missing?
HXS only sends a hardwired PC# when a preset is loaded. It doesn't have the configurable Command Center feature.
So I've been using my Helix floor with a Voodoolabs Hex switcher to incorporate different drive pedals, per snapshot. I'm a MIDI novice so it took me a while to get this configured.
For me, the idea of HX Stomp is appealing because I could put it right on the board with my drives.
Can HX stomp send out MIDI per snapshot?
No.
Default Program Change messages are sent on preset selection - 01A=000;01B=001 etc - but that's it.
Yes. No. Maybe.
The Supersonic 60 Manual shows a single 1/4" footswitch jack which connects to a 3 button switch. Assuming that the switch has a TRS connector which shorts Tip to Sleeve/Ring to Sleeve/No Shorting or some combination;
AND
You're willing to use one function per Preset;
THEN
Yes.
You'd need to use a continuity tester to figure out how the switch buttons work, then decide how many combinations there are and how many you want to use. Each configuration would require a separate HXS Preset.
So, If there's six possible configurations, to have all of them available for a given HXS Preset you'd have to copy it to six slots, then set up six presets on the VDL.
BUT, if all you want is to switch channels, you just need two. Per Preset.
A big PITA and seriously limits the number of presets and complexity of your HXS preset plan, but it's doable.
Maybe.
It's also possible to tow a 50 foot trailer with a Mini Cooper. Maybe.
I appreciate the creativity and comedy of this solution. Seriously got me laughing when I read the Mini Cooper part :)
I still use multiple midi commands in one Patch, which are triggered by changing Snapshot. Wish this was a function on HXS.
Maybe an HX Stomp Deluxe more the size of HX Effects would be the solution. (I'll look for my royalties checks if they actually make one lol)
From what I've read on other forums, Line 6 could have included the MIDI Command Center in the Stomp (they had room for it in firmware and the hardware was in place). One reason it was left out was reportedly that they wanted to keep the Stomp "simple" and adding the MIDI capabilities would have required another chapter in the manual.
Bah! I would prefer using a small Stomp instead of the HX FX at solo gigs, but the lack of MIDI functionality is a show stopper for me.
[BONUS. Sad but true story: my neighbors bought a 40+ foot motor home and a Mini Cooper to tow behind. Somehow the parking brakes got locked on the Cooper, and someone flagged them down on a California freeway saying the car in tow was on fire. The Cooper looked like a marshmallow by the time the fire department arrived. At least they got it unhitched so the RV didn't burn up too.
I seem to recall over on TGP that DI HINTED at the POSSIBILITY that Command Center might make it onto HXS sometime in the future. I could be wrong (wishful thinking), but it sure would be nice.
  • Upvote 2
2 minutes ago, soundog said:
I VOTED!!! x3
Are there any experiences in how to control the Stomp via MIDI by YAMAHA GENOS?
I just like to switch the programs using a muted Voice witch i build on YEM. But i can choose only LSB and PC-number on the YEM. I don't find any CC69. Sorry i'm not that big in MIDI.
Hi folks. I recently got my Stomp. I use Musicomlab as a switcher and midi controler. Now, it is possible to use a Stomp this way: 1st bank i switch between the 3 presets with Stomps footswitches, the rest of the presets (from 2A on...) I use midi controller...?
Thank you!
Thank you!
Hi!!
I'm using musicomlab mk iv, but i have a kind of lag when change between presets. For example
Bank 1 preset 1, change to bank 1 preset 2, there's the lag.
have you a similar issue?
10 hours ago, reyhykary said:
Hi!!
Are you talking about the actual change, or the audio drop between presets?
The audio drop is a result of the process of unloading a preset and loading another, and is unavoidable.
Just tried it using my FCB1010, the change is virtually instantaneous.
If there's a lag in the time it takes to change presets, that would be MIDI latency, and I'd look to the controller for that problem.
Unlike Helix Floor/Rack/LT or HX Effects, HX Stomp isn't a MIDI controller, nor was it ever intended to be. Everything it can do via MIDI is explained in detail starting on page 48. Out of curiosity, what's missing from the manual?
