DrFishhead Posted December 27, 2018 Share Posted December 27, 2018 I've seen in multiple threads and the manual that you should be able to change the variax model per snapshot; however, it only seems to allow it globally or per preset. Using "HX edit 2.6" (in the first image) you can see that there is an option for snapshot clicking on the camera in the upper right. But in the actual selection area (second image, right side), you only have the global and preset option, nothing on snapshots. I have a JTV59 I think it is, and am using the cat5 cable between it and the helix. Although this snapshot option should be visible independent of the variax. I didn't see anything in the release notes for HX edit that addresses it so I doubt upgrading will fix it. Has anyone else run into this or is there a work around? Thanks, Bobby Quote Link to comment Share on other sites More sharing options...
brue58ski Posted December 27, 2018 Share Posted December 27, 2018 Right click below where the per preset button is. Where the model names are. You should get a menu with many different options. Snapshots is at the bottom. Select that. The Model will then be in parentheses just to tell you it is controlled by something. In this case, snapshots. 1 Quote Link to comment Share on other sites More sharing options...
DrFishhead Posted December 27, 2018 Author Share Posted December 27, 2018 Nice, thanks. That looks like it worked. So on the 'preset variax model' line right click---not obvious---on the menu to select it and a new menu of the models pops up. brue58ski: achievement unlocked! Quote Link to comment Share on other sites More sharing options...
