tap tempo on HX Effects
lckx
hello, with a simple delay, i wonder why when i changed tempo by tap tempo switch, the red light is following the tapped tempo, but i get no changed tempo on sound.
delay stayed with the same time as before.
can you help me?
Your delay is likely set to a fixed millisecond, you just need to change that to a subdivision.
To use tap tempo you need to change the time setting on the delay. You do this by "pushing the button" for the time setting... this changes it from ms to subdivision. Then you choose a subdivision to use.... eg: 1/8th, dotted 1/8th, 1/4, etc... etc...
