Euripide Posted December 31, 2018 Share Posted December 31, 2018 I want to set a compressor gain at 4.0 on Snapshot 1 and a gain of 6.0 on snapshot 2. It doesn't work at all: all the snapshots recall only the same setting, the last one... The snapshots seem only capable of recalling if a block is off or on. Is it normal? I guess not, it is quite useless if the snapshots cannot recall the different parameters settings inside a block from snapshot to snapshot. What could I've been doing wrong? Helix V2.71 Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted December 31, 2018 Share Posted December 31, 2018 I'm assuming you haven't read or watched any videos about how to use snapshots? In order to change values on any of the parameters in a block you have to first push in the knob and make the change to the value. That surrounds the value with brackets and allows you to change that value on different snapshots. You might want to take some time and watch Jason Sadites YouTube video on how to work with snapshots as that will likely lead to less confusion. 1 Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 31, 2018 Share Posted December 31, 2018 Any parameter that you want to have values recalled with preset changes needs to be assigned to a snapshot controller (or any controller, really).The shortcut for assigning a parameter to a snapshot controller for the unit itself is to push and turn the knob for that parameter. When you do that, you’ll see brackets appear around the parameter, indicating that it’s now assigned to a snapshot controller. 1 1 Quote Link to comment Share on other sites More sharing options...
Euripide Posted December 31, 2018 Author Share Posted December 31, 2018 Thank you Phil: once I've set the parameter on the Helix itself, I was able to see how to do it in HX Edit. I'm new to Helix (couple of days old) and really love it! Quote Link to comment Share on other sites More sharing options...
