Is this a bug?
JeremiahEdward
I just picked up a second hand helix. I'm setting a/b split to State 1= 100% A and State 2= Even Split when the footswitch is clicked.
Even if I set State 2 to even split and save it, whenever I click from State 1 to State 2, it always reverts back to 100% B instead of Even Split.
Google drive Link with video:
https://drive.google.com/file/d/1zzBYOhVVPP1ItCHWcS-FLBHfCL58XWlj/view?usp=drivesdk
That video doesn't look like you are editing the value in the right place. You are only temporarily changing it.
1: Instead of changing the value with the small button under the "route to" label... push and hold that button.
2: That opens new options... the footswitch should be assigned already... but further to the right is "min & max values"
3: The MIN value is your "State 1" (as you call it) value, the MAX value is your "State 2" value.
4: Save the changes and test the results.... it should work!
Thank you. This is directly related to the question I asked last night as well. How do you set the min/max in the HX edit application?
Edit: found it in the "Bypass/Controller Assign section of HX Edit. I usually do the controller assign on the unit because then I know physically where the button is. Can never remember which is footswitch 7, and so on.
