Recording With Pod Hd 500 Question
savon
Hello guy's
Is it better to plug the left and right output of the hd500 directly in the soundcard
or in a mixer, than in the soundcard.
win  7
cubase sx3
m-audio 2496
mixer tapco mix120
Nad C316 Bee, sound system
Tank you  very much
Hi Savon,
You can connect via s/pdif on the 24/96 using the midi connector cable also has a s/pdif in and out.
If not. the cable then connect to the outputs from the HD500 left/ right outs, either xlr or TS jack outs.
Probably a stereo  phono cable with a couple of 1/4' phone jack adapters should do the trick.
If from the XLR outs you can make a cable not connecting the earth at the phono cable end.
You can hook up your monitors out from the 24/96
