lcuani 0 Posted January 9, 2019 Hi. Is there anyway to use send/ return 1 twice in the same preset? I want to use presets in witch i use path 1 to mag pickup and 2 to piezo ( both played at the same time ). i am using the pickup through the aux in. I have a POG2 that i want to use both in the piezo and mag signals. Is there any way to do that? Thanks in advance Quote Share this post Link to post Share on other sites
phil_m 4,522 Posted January 9, 2019 You can use multiple instances if the same Send block, but not of the same Return block. So you could probably do something merging two paths together before the Return. The bigger issue, though, is that the POG 2 is a mono effect, so you would lose any separation of those signals going into it. Quote Share this post Link to post Share on other sites
lcuani 0 Posted January 10, 2019 On 1/9/2019 at 11:28 AM, phil_m said: You can use multiple instances if the same Send block, but not of the same Return block. So you could probably do something merging two paths together before the Return. The bigger issue, though, is that the POG 2 is a mono effect, so you would lose any separation of those signals going into it. Wel .. this sucks :( I intended to use Digitech the Drop the same way.. Ty mate Quote Share this post Link to post Share on other sites
