TBone55 Posted January 9, 2019 Share Posted January 9, 2019 I've been trying to assign two effects to one footswitch so that I can toggle between the two, turning one on and the other off and vice-versa. The issue I'm having is that I can't get the footswitch indicator to light for the effect I want it to show when lit. I'm using a compression and a distortion effect and I'd like the indicator to light when I have the distortion turned on and the indicator light to be blank when I have the compressor turned on. I can get it to work but it's in the reverse order to what I want. I tried to look this up in the manual but it doesn't really explain how to do it, just that you can either have two effects on or off at the same time or have one on and one off and vice-versa when using a single footswitch. Is there some kind of order that needs to be followed? Thanks Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted January 10, 2019 Share Posted January 10, 2019 4 hours ago, TBone55 said: I can't get the footswitch indicator to light for the effect I want Can't change that unless you change the order of the effects. 4 hours ago, TBone55 said: Is there some kind of order that needs to be followed? The first one in the chain takes the light priority. 1 Quote Link to comment Share on other sites More sharing options...
TBone55 Posted January 10, 2019 Author Share Posted January 10, 2019 2 hours ago, pianoguyy said: Can't change that unless you change the order of the effects. The first one in the chain takes the light priority. Thanks kindly for your help. I had a feeling that might be it. Cheers! Quote Link to comment Share on other sites More sharing options...
