mapletop Posted January 11, 2019 Share Posted January 11, 2019 was looking for a pedal to work the m20d will a radial big shot aby amplifier switcher work? Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 11, 2019 Share Posted January 11, 2019 What exactly do you mean by 'to work the M20d'? Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted January 14, 2019 Share Posted January 14, 2019 Simple answer is, I guess, NO. Most of the functionality of that item will be irrelevant when used with the M20d To use aither of the two remote channels you need a simple on/off switch for each. Some of the control options allow use of a momentary type switch, others require a latching switch. I bought a BOSS FS-6 (to control both) though an FS-7 (new since I bought) will do the same job. Alternatively, two FS-5's will suffice. I rigged up a two channel multicore cable with a TRS jack at the footwsitch end, and TS jacks on the mixer end. Used the functionality... ONCE and decided not to bother lol Palmer have simple switch options too and Radial may even do something though it seems overkill to go down the Radial route for what is essentially an on/off loop. Quote Link to comment Share on other sites More sharing options...
