ChrisClaytonLoop Posted January 11, 2019 Share Posted January 11, 2019 So I just got the HX Effects to replace my M9, along with other stomps from my pedalboard. I currently am running the gigrig generator to power everything except the m9, I am using the line 6 power supply for that. The guys at gigrig said the Generator should power everything, but when I hooked up my m9, the screen was all weird and patchy. The sound was fine, but I couldn't read the screen at all. I even plugged the generator alone into the m9 ans still the same thing. There was a lot of weird white noise when plugged in as well. I was hoping to use the generator with the HXFX, but I'm curious if anyone has had success with it, along with other pedals. I should list what I'm running. I have 2 buffers (I run 2 signals through the board, maybe I don't need them), a small 3 channel looper, Boss DD-6, Boss OC-3, Boss BF-2, Boss RC-300, and then the HX Effects. And where I have the hxfx located I dont like the power cord hanging off the top if the board, since the power supply is straight and not right angled. Quote Link to comment Share on other sites More sharing options...
ElPapo Posted January 16, 2019 Share Posted January 16, 2019 IN the my case I have the HX stomp , and i had some noise issues till I power JUST the HX- Stomp from the DISTRIBUTOR and everything go to one of the gigrig ISOLATOR and that solve all my issues . Not too sure about m9 I'd would using an isolator or different module like the evenFlo , but I believe the polarity on that is reversed . Quote Link to comment Share on other sites More sharing options...
ChrisClaytonLoop Posted January 17, 2019 Author Share Posted January 17, 2019 Thanks for letting me know. I tried plugging the HX in by itself and the distributor would shut off. I have a doubtful feeling that it will work. Quote Link to comment Share on other sites More sharing options...
