Sign in to follow this
mapletop
octave
ive heard this but where  or how do you make a octave pedal?so i can assign it to a button.thanks looking for the leslie west thing
- add a block (preferably in front of your amp, because the tone will be more precise)
- chose a model from the "Pitch/Synth"-list, for example "Simple Pitch"
- turn the "Interval" to "-12" (one octave down) or "+12" (one octave up)
- adjust the other parameter (Cents, Delay etc.) to achieve "your sound"
- push the "MODE"-switch to select the stomp mode
- move the joystick to your block (Simple Pitch)
- touch the desired footswitch for a second, the assign menu will be opened
- press "OK" (button 6)
Have fun! :-)
What he said above, but here's what I do to sim feedback:
Set the minimum to +12 or +24, same interval for the maximum, then use an expression pedal set to adjust mix with minimum set to zero and max set around 75%.  Works pretty damn good and will do until the powers at L6 determine that we've whined an appropriate amount to put a feedback stomp sim in the fx pool.
Create an account
Register a new account
Sign in
Sign In Now
