danmac1
HD500X through MESA Dual Rectifier fx loop
Hi
i hope someone can help. I’ve just updated my knackered old Pod XT Live for the HD500X and I’m running into problems running it through the effects loop of my MESA Dual Rectifier. I seemed to have tried every option, but even with no effects and amps/cabs on the HD, when I pump the volume up on the clean channel of the Rectifier  the volume drops drastically and a horrible high-pitched feedback appears. If I disengage the HD (by turning the Loop option off on my Rectifier pedal) the volume returns to normal and all is well!
When I turn the Rectifier down to eliminate the feedback and compare the loop signal with the unlooped signal the loop signal has more treble bias.
any ideas are welcome!
Thanks!
Hi
Thanks for the reply.
I’ve set my HD to Line on the 1/4” out and 3.5 impedance but it’s still doing the same thing. On the back of the MDR there is a Loop Level, but even with this set to almost nothing the same thing happens. In desperation, I tried it the old fashioned way -HD to the front of the amp, but I can’t deal with distorted delay and reverb!
What I didn’t say, was that I also use a Roland GR55 so my signal path is this;
Guitar to GR55
GR55 guitar out to front of amp
Amp Send to Guitar In of HD
Mono out of HD to Amp Return
using the GR55 and bypassing the HD sounds fine.
Hi
the only thing I had was the Pod st live which is now sold, but that worked fine.
Hi
I’ll try that tomorrow. I’m just giving my ears a rest now!
thanks again
Dan
The fx loop of mesa  are in parallel instead of serial. So you have to be 100% wet to avoid phase problems
Hi
thsnks for the info Melissiah. Do you mean the fx loop send level on the back of the amp?
No leave them to 12o clock. It’s in the helix that have to be 100% wet. Example if you use a delay you have to put it in a dual path with send return in that second path and set the mix dry/wet to 100% instead of 50%. This way you won’t have the phase problem that mesa parralel loop cause.
