Lehle mono volume with Helix Floor
rockinb
Can a LEHLE MONO VOLUME  pedal be used with the Helix floor to be an overall volume pedal allowing the onboard exp pedal to do other things ?  If so, please provided info on the best way to set this up .   Thx in advance ....
"Best way" depends on how you have your rig set up  :)
One way is to simply place the Lehle in between the Mono 1/4in Jack out and your FR monitor speaker.  Some folks use that method.  Of course it only works if you are using a mono jack output - not stereo or via the XLRs.
Another way would be to place it in within a Send / Return Loop and then pop a Send/Return block into your signal chain - though this would mean passing your guitar signal through an extra stage of AD and DA conversion so I would not do that personally (and again it is only Mono)
Or you could modify the Lehle so it functioned as an actual expression pedal - there are a few posts on the forum about that I think.
  • 1 year later...
