GaryWalker1974 3 Posted January 16, 2019 Hi All, I need some help please, I have tried both 2CM and 4CM and when I play through the preset or indeed even a blank preset....it sound WAY duller than direct into the amp!! I would have thought with nothing on the preset it should just be a close representation of direct into my amp it sounds like im just playing into the power amp and missing out the pre amp, however it is far from that. I do not have any global EQ on, My cables are all working fine and of a very high quality, My amp is a Friedman JJ that sounds awesome straight in. any ideas folks??? many thanks Gaz Quote Share this post Link to post Share on other sites
Kilrahi 488 Posted January 16, 2019 2 hours ago, GaryWalker1974 said: Hi All, I need some help please, I have tried both 2CM and 4CM and when I play through the preset or indeed even a blank preset....it sound WAY duller than direct into the amp!! I would have thought with nothing on the preset it should just be a close representation of direct into my amp it sounds like im just playing into the power amp and missing out the pre amp, however it is far from that. I do not have any global EQ on, My cables are all working fine and of a very high quality, My amp is a Friedman JJ that sounds awesome straight in. any ideas folks??? many thanks Gaz Well yeah, tons of ideas. More information is kind of needed. My first question, is this your first time using a modeler? Have you always just been a guitar in to amp kind of guy? Quote Share this post Link to post Share on other sites
rd2rk 1,162 Posted January 16, 2019 Might be helpful to describe EXACTLY your cable routing in 4cm, and attach a preset (not a screenshot) that behaves this way in that mode. Quote Share this post Link to post Share on other sites
DarthHollis 236 Posted January 16, 2019 First thing I would suggest is turning the volume knob on the Helix all the way up. That is unity gain. Then make sure your connections are correct and that you are using the correct Line/Instrument level that is appropriate with the JJ input and FX loop. The FX loop in the JJ is probably instrument level but I do not know. If it's line level that could be a problem. Last thing is are you using a really long cable? More that 15 feet and you will probably notice a loss of high end, even in the FX loop. I did using 30' cable with my 5150 III. If you can provide more info we will continue to try to help. Quote Share this post Link to post Share on other sites
DunedinDragon 960 Posted January 16, 2019 Given your description there could be any number of problems with your setup or the construction of the preset. In all honesty it's probably multiple issues. We don't even know what your setup is as far as amp, or what kind of presets you were using, or the signal level you're sending...blah blah blah. You're going to have to be a bit more verbose and detailed in your description if you want to get some help figuring out what's going on... Quote Share this post Link to post Share on other sites
GaryWalker1974 3 Posted January 17, 2019 HI Guys, Thanks for all your replies, 4CM runs as follows... GTR INTO HELIX INPUT HELIX SEND TO AMP INPUT FX SEND ON AMP INTO HELIX RETURN MAIN OUT OF THE HELIX TO THE FX RETURN ON MY AMP CABLES ARE 20FT WITH A BUFFER ON BOTH THE HELIX LINE IN AND MAIN OUT I'VE USED VARIOUS MODELERS BEFORE AND LETS SAY THE PRESET IS COMPLETELY BLANK BAR THE FX BLOCK RELATING TO THE LOOP FOR 4CM. EVEN IF I GET THE HELIX TO UNITY GAIN IT STILL JUST SOUNDS LIKE I'M JUST PLUGGED INTO THE FX LOOP AND MISSING OUT THE FRONT PRE-AMP. CHEERS ALL GAZ PS. DOH! JUST REALIZED I'VE LEFT CAPS LOCK ON... Quote Share this post Link to post Share on other sites
DarthHollis 236 Posted January 17, 2019 Do you have an FX loop block in the Helix? That has to be engaged and set to the right output level (line or instrument). I highly suggest you use one of the templates from the setlists. There is one for 4CM. Setlist #8 - Templates, patch 2A - 4-Cable Method. Quote Share this post Link to post Share on other sites
GaryWalker1974 3 Posted January 17, 2019 Thanks for the reply, I’ll try one of the set list you mentioned. I think I’ve got everything set up right to be honest but hey I’ll give anything a bash. Quote Share this post Link to post Share on other sites
arislaf 856 Posted January 17, 2019 Check your impedance settings on helix make sure it is set to 1 Quote Share this post Link to post Share on other sites
