simmerswitch_ Posted January 17, 2019 Share Posted January 17, 2019 I'm experiencing an issue where, whenever I place effects on a B path, my overall output volume becomes louder than other Presets, when those fx on the B path, are switched off. EG: 'Preset A' has all effects on a single 'Path'. This preset produces intended Output Level 'Preset B' has some effects on a 'B Path', that 'B Path' merges before the end of the Signal Chain. This preset produces an Output Level louder than 'Preset A' when effects on Path B are OFF Both presets have the same parameters for the 'Split' and 'Merge' blocks (that being Center/0dB) How do I easily ensure uniform levels across presets, when some are using a B Path? I don't understand why I have to fiddle around with A and B levels in the Merge parameter. It should Merge at the same level as a preset without a split/merge. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 17, 2019 Share Posted January 17, 2019 Be helpful if you attached the two presets in question. Quote Link to comment Share on other sites More sharing options...
simmerswitch_ Posted January 17, 2019 Author Share Posted January 17, 2019 14 minutes ago, rd2rk said: Be helpful if you attached the two presets in question. I can't do that right now. Also, my setup has an Amp 4CM in FX1 and an external OD in FX2, so might be hard to replicate without my same setup. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 17, 2019 Share Posted January 17, 2019 Some of us have amps and overdrives. But mainly we'd be looking for obvious and not so obvious configuration problems. Quote Link to comment Share on other sites More sharing options...
codamedia Posted January 17, 2019 Share Posted January 17, 2019 10 hours ago, simmerswitch_ said: 'Preset B' has some effects on a 'B Path', that 'B Path' merges before the end of the Signal Chain. This preset produces an Output Level louder than 'Preset A' when effects on Path B are OFF Without having a patch to try (or even look at), this looks like a leveling issue. Turn all effects in path B off Go to the "merge" block and turn down path B until you have the balance you want? Add the effects to path B one by one, adjusting the level/balance on those effects until the volume is even whether they are on or off. 10 hours ago, simmerswitch_ said: I don't understand why I have to fiddle around with A and B levels in the Merge parameter. It should Merge at the same level as a preset without a split/merge. Parallel paths can be tricky to balance. The signal on path B is not processed by any effects it is bypassing from path A, so it can vary in volume depending on your setup. Since none of us has access to your preset, we can only generalize. Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 17, 2019 Share Posted January 17, 2019 Also check the Level parameter on the Path B Output block. Quote Link to comment Share on other sites More sharing options...
perapera Posted June 19, 2019 Share Posted June 19, 2019 you may find this helpful: cheers Lorenzo Quote Link to comment Share on other sites More sharing options...
