Sign in to follow this
modelation
Interesting Problem With Sound Cutting Out
I couldn't figure out why my sound was randomly cutting out on certain presets and then I tracked down what was going on. Apparently the Helix does not sense expression pedal positions when changing to a new preset. When I switch to a preset using a volume expression pedal and the pedal is in the heel down position, the preset comes on at full volume. When my guitar cord lightly brushed up against the volume pedal, the volume would cut out until I rock the pedal forward. Maybe something to fix on a future release.
Maybe this snip from the manual will help. See Global Settings -> EXP x Pedal Position:
Determines whether the Helix expression pedal positions are recalled per snapshot, per preset, or applied globally. If you want a Volume Pedal or Wah to maintain its position when switching presets, set this to "Global."
Yep, global setting should fix that. When I first got it I thought that was the expected behavior, so I turned it down, powered on the unit, and got BLASTED with feedback from a patch that had been saved with the volume full up and no noise gates. Fun times.
Yes, the global setting solved the volume expression pedal issue. Thanks.
But I did notice that it has trouble detecting expression pedal positions for other effects. For example switching to a preset using a wah expression pedal that is in the toe position starts out very muted-bassy like the pedal is near the heal position. Move the pedal back and forth to the toe position and it sounds like a normal wah in the toe position.
Create an account
Register a new account
Sign in
Sign In Now
